RD-SL-T: 1010 Wheel Impact Analysis
This tutorial demonstrates the impact of a wheel.
In this lesson you will learn how to:
  • Define material and properties
  • Create a rigid body property and apply nonstructural mass
  • Define initial conditions, spring damper connection and friction (TYPE24) contact
  • Configure the solution parameters, output requests and review results
Prerequisites
To run this simulation, you will need access to a licensed version of SimLab and Radioss. You will need an internet connection to watch the video tutorials and download the files.
Model Files
Tutorial Video
Additional Resources
For more tutorials, visit the SimLab Learning Center.
