/DYREL/1
Engine Keyword Dynamic relaxation applied to node group identifier grnd_ID.
/DYREL/1
grnd_ID
β T
grnd_ID Node group identifier.
β
Relaxation factor.
Default = 1.0
T Period to be damped.
V t + Δ t / 2 = ( 1 2 ω ) V t Δ t / 2 + ( 1 ω ) γ t Δ t with ω = β Δ t T
  1. Can be used only if Starter Input uses Block Format.
