Radioss Files
Input Format
The input format (V41, V44, V51, V90, and so on) corresponds to the format of the Radioss input data file, whose name is RunnameD00 for input formats up to V44 or Runname_0000.rad for input formats coming from V51 or higher.
For input formats up to V44, the input format is declared at the first line of the Starter input file. This conforms to the version of the input manual.
For input formats from V51 onwards, the input format is declared in the keyword /BEGIN, which must be the first uncommented line after the line: “#RADIOSS Starter”.
For every new Radioss main release (V41, V44, V51, V90, and so on), a new input manual is provided, which presents the characteristics of the new input format, and information on new keywords.
By ascending compatibility, a RunnamD00 or Runname_0000.rad file conforming to a given manual will be read normally by the next Radioss release (but not the opposite).
** ERROR IN INPUT FORMAT INPUT VERSION 42 IS NOT SUPPORTED
Version 12.0 and After
| 4x Extension Format | 12x Extension Format | Type | Format | Remark | Read by | Written by |
| RunnameD00 | Runname_0000.rad | Starter input | ASCII | Starter | HyperCrash
HyperMesh |
| RunnameDnn | Runname_run#.rad | Engine input | ASCII | Engine | User | |
| RunnameRnn | Runname_run#_cpu # [_C].rst | Restart file | Any | Default binary | Engine | Starter Engine |
| RunnameRnn | RunnameAnnn | Animation | IEEE binary | HyperView | Engine | |
| N/A | Runname.h3d | Animation | H3D | HyperView | Engine (starting in 2018) or HvTrans thru run script | |
| RunnameTnn | if Radioss Engine option
/TH/VERS/41 is used
(default): RunnameTnn |
Time history | Any | Default IEEE binary | HyperGraph | Engine |
| RunnameTnnx | if Radioss Engine option
/TH/VERS/41 is used
(default): RunnameTnnx if Radioss Engine option /TH/VERS/51 is used: Runname_run#_x.thy “x”: letter (a to i) |
| Runname@Tnn | Runname_run#_@.thy | MNOISE file | Any | HyperGraph | Engine | |
| RunnameLnn | Runname_run#.out | Listing | ASCII | Engine | ||
| RunnameLnn | Runname_nnnn.sty or
RunnameYnnn according to the /IOFLAG keyword if Irootyy = 2: RunnameYnnn if Irootyy ≠ 2: Runname_#run.sty |
Output | ASCII | Starter | Engine | |
| Runname_run#.sta | State file | ASCII | Starter | Engine | ||
| RunnameCnn | Runname_run#.ctl | Control files | ASCII | Engine | User |
run# : RADIOSS run number (four digits) from 0000 to 9999
cpu # : number of processors (four digits)
cpu # = 0000 = SMP RADIOSS Version
cpu # = 0001 to 9999 = MPP (SPMD) RADIOSS Version
C: restart letter (see /RFILE option in the RADIOSS Engine manual)In case of Single Input File, Engine options can be added into Starter file. Refer to Single File Input for details.
Version 9.0
Runname_run#.lis becomes Runname_run#.out
Runname_nnnn.out becomes Runname_nnnn.sty
| 9x extension | Type | Format | Remark | Read by | Written by |
HyperMesh |
| Runname_0000_a.rad | Starter input | ASCII | Starter | HyperCrash
HyperMesh |
| Runname_run#.rad | Engine input | ASCII | Engine | Engine | |
| Runname_run#_cpu#[_C].rst | Restart file | Any | Default binary | Engine | Starter Engine |
| Runname.h3d | Animation | H3D | HyperView | HvTrans thru run script | |
/TH/VERS/41 is used
(default): RunnameTnn if Radioss Engine option /TH/VERS/51 is used: Runname_run#.thy |
/TH/VERS/41 is used
| Runname_run#.out | Output | ASCII | Engine | ||
| Runname_nnnn.sty or
RunnameYnnn according to the /IOFLAG keyword: if Irootyy = 2: RunnameYnnn if Irootyy ≠ 2: Runname_#run.sty |
| Runname_nnnn.sta | State file | ASCII | Starter | Engine | |
| Runname_run#.ctl | Control file | ASCII | Engine | User |
run#: RADIOSS run number (four digits) from 0000 to 9999
cpu #: number of processors (four digits)
cpu # = 0001 to 9999 = SPMD RADIOSS Version
Version 5.1
| 5x extension | Type | Format | Remark | Read by | Written by |
HyperMesh |
HyperMesh |
/TH/VERS/41 is used
/TH/VERS/41 is used (default):
| Runname_run#.lis | Listing | ASCII | Engine | ||
| Runname_nnnn.out or
RunnameYnnn according to the /IOFLAG keyword: if if |
Version 4 and Earlier
| 4x extension | Type | Format | Remark | Read by | Written by |
| RunnameD00 | Starter input | ASCII | Starter | HyperCrash
HyperMesh |
| RunnameD0A | Starter input | ASCII | Starter | HyperCrash
HyperMesh |
| RunnameDnn | Engine input | ASCII | Default binary | Engine | User |
| RunnameRnn | Restart file | Any | Engine | Starter Engine |
| Animation | H3D | HyperView | HvTrans thru run script | ||
| RunnameTnn | Time history | Any | Default IEEE binary | HyperGraph | Engine |
| RunnameTnnx | Time history | Any | Default IEEE binary | HyperGraph | Engine |
| Runname@Tnn | MNOISE file | Any | HyperGraph | Engine | |
| RunnameLnn | Listing | ASCII | Engine | ||
RunnameYnnn |
| RunnameCnn | Control file | ASCII | Engine | User |
