/IMPL/DT/FIXPOINT
Engine Keyword Users' input fix time points where implicit nonlinear computation will not miss with automatic time step control.
/IMPL/DT/FIXPOINT
T1, T2, ... Tn (n<100)
T1, T2, ... Tn Users' input fix time points. Implicit nonlinear computation will not be missed with automatic time step control at this points.
