/IMPL/PRINT/LINEAR
Engine Keyword Printout frequency for linear solvers.
/IMPL/PRINT/LINEAR/Nprint
Nprint Printout frequency for linear solvers (works also in nonlinear analysis but rather as debug uses).
  1. This keyword is mainly used for iterative solver. When a direct solver has been used, only relative residual will print out and only in case of linear analysis.
