/IMPL/QSTAT/DTSCAL
Engine Keyword Quasi-static implicit solution with a factor for inertia stiffness matrix.
/IMPL/QSTAT/DTSCAL
Δ T sca1
Δ T sca1 Scale factor of inertia stiffness matrix used in quasi-static analysis.
  1. Inertia stiffness matrix will be scaled inversely square proportional like time-step.
