/STATE/STR_FILE
Engine Keyword When writing the state file, /INISHE, /INISH3 and /INIBRI will be written in a separate file which can be asked for being compressed (using GZIP) or not. The state file will then resume to the nodes coordinates and element connectivity.
/STATE/STR_FILE
Izip
| Izip | Define if the
.str file will be compressed flag.
(Integer, maximum 10 digits) |
- The .sta file will refer to the stress file by including the
option:
/STATE/STR_FILE Izip Stress_File_Name - The stress file name will be Runname_nnn#.str, where Runname is the Run Name (see /RUN) and nnn# is the file number (four digits) from 0001 to 9999 (same as the state file number).
