Radioss
Radioss
2022
  1. Home
  2. Theory Manual
  3. Large Displacement Finite Element Analysis Theory Manual
  4. Element Library
    Radioss element library contains elements for one, two or three dimensional problems.
  5. Beam Type Spring Elements (TYPE13)
  6. Multidirectional Failure Criteria
  • What's New
  • Overview
  • Tutorials
  • User Guide
  • Reference Guide
  • Example Guide
  • Verification Problems
  • Frequently Asked Questions
  • Theory Manual
  • User Subroutines
  • Starter Input
  • Engine Input
Index
Radioss
2022
Radioss
  • What's New
    View new features for Radioss 2022.
  • Overview
  • Tutorials
  • User Guide
  • Reference Guide
  • Example Guide
  • Theory Manual
    • Large Displacement Finite Element Analysis Theory Manual
      • Introduction
        Nonlinear finite element analyses confront users with many choices. An understanding of the fundamental concepts of nonlinear finite element analysis is necessary if you do not want to use the finite element program as a black box. The purpose of this manual is to describe the numerical methods included in Radioss.
      • Basic Equations
      • Finite Element Formulation
      • Dynamic Analysis
      • Element Library
        • Solid Hexahedron Elements
        • Solid Tetrahedron Elements
        • Shell Elements
        • Solid-Shell Elements
        • Truss Elements (TYPE2)
        • Beam Elements (TYPE3)
        • One Degree of Freedom Spring Elements (TYPE4)
        • General Spring Elements (TYPE8)
        • Pulley Type Spring Elements (TYPE12)
        • Beam Type Spring Elements (TYPE13)
          • Time Step
          • Linear Spring
          • Nonlinear Elastic Spring
          • Nonlinear Elasto-Plastic Spring - Isotropic Hardening
          • Nonlinear Elasto-Plastic Spring - Decoupled Hardening
          • Nonlinear Elasto-Plastic Spring - Kinematic Hardening
          • Nonlinear Elasto-Plastic Spring - Nonlinear Unloading
          • Nonlinear Dashpot
          • Nonlinear Visco-Elastic Spring
          • Skew Frame Properties
          • Sign Conventions
          • Tension
          • Shear - XY
          • Shear - XZ
          • Torsion
          • Bending About the Y Axis
          • Bending About the Z Axis
          • Multidirectional Failure Criteria
        • Multistrand Elements (TYPE28)
          Multistrand elements are n-node springs where matter is assumed to slide through the nodes.
        • Spring Type Pretensioners (TYPE32)
      • Kinematic Constraints
        Kinematic constraints are boundary conditions that are placed on nodal velocities. They are mutually exclusive for each degree of freedom (DOF), and there can only be one constraint per DOF.
      • Linear Stability
        The stability of solution concerns the evolution of a process subjected to small perturbations. A process is considered to be stable if small perturbations of initial data result in small changes in the solution. The theory of stability can be applied to a variety of computational problems.
      • Interfaces
        Interfaces solve the contact and impact conditions between two parts of a model.
      • Material Laws
        A large variety of materials is used in the structural components and must be modeled in stress analysis problems. For any kind of these materials a range of constitutive laws is available to describe by a mathematical approach the behavior of the material.
      • Monitored Volume
        An airbag is defined as a monitored volume. A monitored volume is defined as having one or more 3 or 4 node shell property sets.
      • Static
        Explicit scheme is generally used for time integration in Radioss, in which velocities and displacements are obtained by direct integration of nodal accelerations.
      • Radioss Parallelization
        The performance criterion in the computation was always an essential point in the architectural conception of Radioss. At first, the program has been largely optimized for the vectored super-calculators like CRAY. Then, a first parallel version SMP made possible the exploration of shared memory on processors.
    • ALE, CFD and SPH Theory Manual
    • Appendix A: Basic Relations of Elasticity
  • User Subroutines
  • Starter Input
  • Engine Input
View All Altair Simulation Help
Radioss
Radioss
2022
  1. Home
  2. Theory Manual
  4. Element Library
  • What's New
  • Overview
  • Tutorials
  • User Guide
  • Reference Guide
  • Example Guide
  • Theory Manual
  • User Subroutines
  • Starter Input
  • Engine Input
Index
See Multidirectional Failure Criteria; the explanation is the same as for spring TYPE8.
