Multistrand Elements (TYPE28)
Multistrand elements are n-node springs where matter is assumed to slide through the nodes.
It could be used for belt modelization by taking nodes upon the dummy. Friction may be defined at all or some nodes. When nodes are taken upon a dummy in order to modelize a belt, this allows friction to be modelized between the belt and the dummy.
Internal Forces Computation
Figure 1. Internal Forces Computation
Nodes are numbered from 1 to n MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4uaaaa@36CE@ , and strands are numbered from 1 to n-1 (strand k MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4uaaaa@36CE@ goes from node Nk to node Nk+1).
Averaged Force
The averaged force in the multistrand is computed as:
Linear spring F = K L 0 δ + C L 0 δ ˙
Nonlinear spring F = f ( ε ) ⋅ g ( ε ˙ ) + C L 0 δ ˙
or, if g MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4zaaaa@36E2@ function identifier is 0:(1)
F = f ( ε ) + C L 0 δ ˙
or, if f MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4zaaaa@36E2@ function identifier is 0:(2)
F = g ( ε ˙ ) + C L 0 δ ˙
Where,
ε
Engineering strain: ε = L − L 0 L 0
L 0
Reference length of element
Force into each Strand
The force into each strand k MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4uaaaa@36CE@ is computed as:
F k =F+Δ F k
Where, Δ F k is computed an incremental way:(3)
Δ F k ( t ) = Δ F k ( t − 1 ) + K l k 0 δ ε k − K L 0 δ ε
with l k 0 the length of the unconstrained strand k MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4uaaaa@36CE@ , δ ε = ε ( t ) − ε ( t − 1 ) and δ ε k = δ t u k ⋅ ( v k + 1 − v k ) .
Where, u k is the unitary vector from node Nk to node Nk+1.
Assuming:(4)
l k l k 0 = L L 0
Where, l k is the actual length of strand k MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4zaaaa@36E2@ .
Therefore, Equation 3 reduces to:(5)
Δ F k ( t )=Δ F k ( t−1 )+ K l 0 ( δ ε k L l k −δε )
Friction
Friction is expressed at the nodes: if μ is the friction coefficient at node k MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4zaaaa@36E2@ , the pulley friction at node Nk is expressed as:(6)
| Δ F k − 1 − Δ F k | ≤ ( 2 F + Δ F k − 1 + Δ F k ) tanh ( β μ 2 )
When equation Equation 6 is not satisfied, | Δ F k − 1 − Δ F k | is reset to ( 2F+Δ F k−1 +Δ F k )tanh( βμ 2 ) .
All the Δ F k (k=1, n-1) are modified in order to satisfy all conditions upon Δ F k − 1 − Δ F k (k=2, n-1), plus the following condition on the force integral along the multistrand element:(7)
∑ k = 1 , n − 1 l k ( F + Δ F k ) = L F
This process could fail to satisfy Equation 6 after the Δ F k ( k = 1 , n − 1 ) modification, since no iteration is made. However, in such a case one would expect the friction condition to be satisfied after a few time steps.
Note: Friction expressed upon strands (giving a friction coefficient μ along strand k MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4uaaaa@36CE@ ) is related to pulley friction by adding a friction coefficient μ / 2 upon each nodes Nk and Nk+1.
Time Step
Stability of a multistrand element is expressed as:(8)
Δt≤ C k 2 +ρ l k K k − C k K k ,∀k
with K k = M a s s   o f   t h e   m u l t i s t r a n d L 0 :(9)
K k = max ( K l k 0 , F l k − l k 0 ) = max ( K L l k L 0 , F L l k ( L − L 0 ) )
(10)
C k = ( f ( ε ) d g d ε ˙ ( ε ˙ ) + C ) l k 0 = ( f ( ε ) d g d ε ( ε ˙ ) + C ) L l k L 0
