Generate multiple sketches to create a parametric bracket with recessed areas using the Offset, Push/Pull, and Boolean
tools, and using a construction line as a reference. You will also assign dimensions and create variables.
Learn how to use constraints and construction geometry to create more sophisticated sketches. In this example, you'll
build a tapering arm for a clamp around a reference centerline, paramaterizing the sketch in terms of the construction
lines.
