Results Menu
This menu allows the user to visualize the computed results for the executed simulation cases. The contents of this menu are shown in the following figure:
Figure 1. Results menu
- The Field submenu contains options to visualize the field at a given height value or range value.
- The Propagation Factor submenu contains options to visualize the propagation factor, that is, the strength of the field relative to the free-space value, at a given height or range value.
- The Path Loss submenu contains options to visualize the path loss, that is, the ratio between radiated power and power available at a point, at a given height or range value.
