Material Non-linear Result Types
Select the non-linear results type to contour plot.
Three types of results are available:
  1. Elasto-plastic, full load – these are the results at full load assuming a non-linear stress-strain curve is used.
  2. Elastic, full load – these are the results at full load assuming a linear (straight) stress-strain curve is used.
  3. After unloading – these are the residual results after loading has been removed.
