SS-V: 5080 Rigid Punch Plasticity Test No. VNL09 Find out reactions at the punch pressed on large block for perfectly plastic and isotropic hardening materials.
SS-V: 5090 Bushing Stiffness Test No. VNL10Find the rotation of cylinder subjected to a moment of 10 N-m along its length.
SS-V: 5100 Buckling Test No. VNL11Find the critical compression load at which a simply supported beam buckles.
