Cleanup Registry to Remove Registered Clusters
Removes the invalid clusters from the system completely.
This feature is applicable for the clusters registered starting from the 2022.1.0 of Access Desktop.
Note: To remove registered clusters from the previous versions of Access Desktop you need administrator rights and clear the details from the system registry.
Refer to the Remove Old Clusters from the Context Menu topic in the Access Desktop 2022.1.0 Administrators Guide for more information.
  1. Open the Windows system tray.
  2. Double-click the Access Desktop icon .
  3. Click .
  4. Select Cleanup Registry.
    A notification message: Registry cleaned up successfully is displayed.
    The invalid registered SSH and HTTPS clusters are removed from the application and the system.
  5. Restart Access Desktop.
    The invalid and the deleted clusters will not appear in the context menu when you right-click an input file.
