Map or add a name to the Webdav drive in your local machine so that the files in the job's running directory on the
HPC complex can be accessed and viewed.
Application definitions are a predefined set of instructions to describe application parameters, store responses and
prepare responses for job execution.
Map a network drive to create a shortcut to the shared file system path.
To map a network drive you will need to know the shared file system path.
Mapping a network drive will help you to access the shared files just the way you
access your local files. When you map a network drive, it will display as a new
drive in the File Explorer.
Open File Explorer.
Perform one of the following options based on Windows version:
In Windows 7, right click Computer and select
Map network drive... from the context
menu.
In Windows 8 or 10, right click This PC and
select Map network drive... from the context
menu.
A Map Network Drive menu is displayed.
Figure: Map Network Drive
Select the drive letter you want to use for the network folder.
Choose one of the following options:
Enter the shared file system path provided by the
administrator.
Click Browse to navigate to the folder or path
you want to map and click OK.
An example of a windows network drive is:
\\hwesuse110-14\share
Enable Reconnect at sign-in, so it is always available
to you when you login to the system.
Enable Connect using different credentials to login to
the mapped network drive with a different user credentials.
