Set Job Submission Notification Set job submission notification to specify for which job state change the email has to be sent. The email has to be set for the job submission notification to be sent. You can set the email in the profile settings. Click . Select Preferences. Access Web Preferences is displayed. Click Job Submission in the left panel. The Job Submission panel is displayed. Note: By default, all the options of job submission notification is disabled. Figure: Job Submission Notification Check any or all of the options in the Notify when job state changes to list to indicate when the email will be sent. Note: You can also enable the job submission form to be closed after submitting the job. Note: Click to go back to the previous page.
