Reset all Preferences
Reset all the preferences to the default settings.
Set to the default settings of Access Web. By resetting to the default settings, you will lose all the saved preferences. For example, you will lose the Saved Filter Options, Columns added to the list view, default job action settings, enabled persistence behavior, notification preference.
  1. Click .
  2. Select Preferences.
    Access Web Preferences is displayed.
  3. Click Diagnosis in the left panel.
    The Diagnosis panel is displayed.
    Figure: Diagnosis Preference
  4. Click Reset All button to set to the default settings.
    Note: Click to go back to the previous page.
