File or Folder Permission
- Click the Files tab located in the upper left-hand of the page.
- Using the file system tree on the left, navigate to the file or folder that you want to set the the required permissions.
Perform one of the following options:
- Right-click on the folder.
- Right-click on the file.
- Right-click on the folder and file.
Tip: You can also select multiple folder or file. Select the first folder or file by clicking its name and hold down CTRL and select each folder or file by clicking its name.
Figure: File or Folder Selection
Select Properties.
The file or folder properties dialog box is displayed.
Figure: File or Folder Permission
Set the necessary permission (read, write, and execute) to the owner, group and
others.
Note: You can select Set permission recursively check-box when you are setting the permission to a folder.
- Click Save.
