View a File
View the files, edit and save, download, tail and delete the files.
  1. Click the Files tab located in the upper left-hand of the page.
  2. Using the file system tree on the left, navigate to the file that you want to view.
  3. Choose one of the following options:
    • If you want to open the file in the default application, double-click the file.
    • If you want to open the file in the default application, right-click the file and select Open in the context menu.
    • If you want to choose an application and to set a default application to open the file, right-click the file and select Open With.
    Tip: To set a default application to open a file based on the file extension, then select Always Use this check-box.
    The file will be opened in the application:
    Figure: Opened File
    Note: You can perform some of the file operations.
    Figure: Opened Image File
    Note: The editing and tailing is only available for certain kinds of files.
    Figure: View File by choosing an Application
