Change the Remote Desktops Presenter
Transfer the control of a remote desktops by changing the presenter.
When you share a remote desktops, you are the Presenter of that remote desktops and the users with whom you have shared are the Viewers. You can use and interact with the application you are presenting. The Viewers of the remote desktops however, cannot interact with the application. In many cases, it becomes necessary to allow the Viewers to interact with the application and make changes. To transfer control and allow a Viewer to interact with the application, you can make the Viewer, the Presenter.
  1. Click next to the shared remote desktops user.
    Figure: Share Remote Desktops Option
  2. Select Make Presenter from the drop-down menu.
    The user will be presenter of the remote desktops.
    Figure: Remote Desktops Presenter
    Note: A notification will be sent to the user indicating that you have changed the role of the user to presenter.
    Note: You can regain control by choosing your name and selecting the Presenter role from the drop-down menu.
