Monitor the status of your jobs, filter the job view, view job details, monitor memory and core utilization, view
a list of job files, or perform job actions.
Change the remote desktops quality settings by changing the frames per second and
bitrate.
By default, the remote desktops quality setting is set to auto adjust based on the
client system for better performance.
Click the Desktops tab located in the upper left-hand of
the page.
Remote Desktops list is displayed.
Figure: Remote Desktops List
Choose one of the following options:
Double click a remote desktops name.
Right click a remote desktops name and click
Open.
A remote desktops of the interactive application is opened.
Figure: Remote Desktops Interactive Application
In the panel located on the left is a list of active remote desktops
and the current remote desktops with the user name. Remote Desktops options are located in the top right-hand
corner.
Click .
Desktop Quality Settings screen is displayed.
By default, the desktop quality settings is set to auto adjust.
Figure: Desktops Quality Settings
Move the toggle switch of Auto Adjust Quality to the
left to change the frames per second and bitrate of remote desktops.
Change the Frame Per Second (FPS) value.
Change the Bitrate (mbps) value.
Click Apply.
Note: Click Reset to set the
quality settings to the default value.
