Disable cloud bursting by disabling bursting scenarios, letting the cloud queues
drain and allowing all cloud nodes to unburst.
All cloud bursting for an HPC complex must be disabled
before any of the following activities:
- upgrading PBS Professional
- performing PBS maintenance
- reconfiguring PBS execution hosts
- changing the amount of PBSWorksBurstNodeHours licenses
Cloud bursting associated to a bursting scenario must be disabled before a
bursting scenario can be edited.
Choose one of the following options:
- Disable all bursting scenarios before any PBS maintenance activities or changing the
amount of PBSWorksBurstNodeHours licenses.
- Disable a bursting scenario before editing the bursting
scenario.
Allow all cloud queues (those associated with cloud bursting) to drain by
allowing time for the jobs that are waiting in the queues to run and
complete.
Tip: If a running job is taking a long time to complete, it can be
deleted using the PBS
qdel command or through the Control
Monitor tab.
Verify that all cloud nodes are unburst.
Login to Control.
Click the Cloud tab.
Click Bursting from
the Infrastructure menu located on the left-hand side of
the web page.
Select a bursting scenario by clicking its name.
Click Node.
When the following message is displayed for both the automatically and
manually burst categories, all cloud nodes are
unburst.
No machines are available
When disabling all cloud bursting, verify that all cloud nodes are unburst for
every bursting scenario.
