Drill-down to get node information about the nodes in a cluster, nodes attached to queue, or a subset of nodes in
either of these categories filtered by a condition.
The real-time dashboard in Control (currently in preview release stage), provides live data in a single page to view
several aspects about the overall operation of a cluster.
Remove a node from the scheduling pool by taking it offline.
Drill-down to get detailed information about the HPC cluster's nodes or
nodes attached to a queue.
Nodes that are taken offline will not accept and run jobs. Jobs that are currently running
on the node continue to run until completion.
Only an entire host/node can be taken offline which takes all vnodes offline. Presently,
individual vnodes cannot be taken offline.
Choose one of the following options to select nodes:
Select multiple nodes by enabling the selection checkbox next to the
nodes and clicking Actions.
Select a single node by clicking next to the state of the node.
Select all nodes on the current page by clicking the Select
All checkbox and clicking
Actions.
Tip: Perform a node search to filter nodes and then use the Select
All checkbox to select all the nodes on the current page matching the search
criteria. Click the reset link to deselect all
nodes. Figure 1. Use Select All Checkbox
As nodes are selected, the total number of selected nodes is displayed.
