Drill-down to get node information about the nodes in a cluster, nodes attached to queue, or a subset of nodes in
either of these categories filtered by a condition.
The real-time dashboard in Control (currently in preview release stage), provides live data in a single page to view
several aspects about the overall operation of a cluster.
Bring nodes online or take nodes offline to indicate whether or not the nodes should
accept and run cluster jobs.
Mark a Node Online
Place a node back into the scheduling pool by marking it online.
Take a Node Offline
Remove a node from the scheduling pool by taking it offline.
Add a Comment to a Node
Add a comment to a node so that information pertaining to the node can be shared such as when a node is going to be taken offline.
