Change the Maximum Size of a Job Script
Limit the size of job scripts.
- Click the Configure tab.
Choose the HPC to configure.
Figure 1. Choose an HPC
- Click Limits from the PBS Professional menu located on the left-hand side of the web page.
Click
located in the upper right-hand corner of the web page.
- Enable the Display Advanced Settings check box.
Click
located to the right of Job Script Size
Limit.
For Job Script Size Limit, enter the maximum size for
job scripts.
The size must be entered in the format integer[suffix] (ex. 200MB) where suffix can be one of the following:
Suffix Meaning Size b or w Bytes or words 1 kb or kw Kilobytes or kilowords 2 to the 10th, or 1024 mb or mw Megabytes or megawords 2 to the 20th, or 1,048,576 gb or gw Gigabytes or gigawords 2 to the 30th, or 1,073,741,824 tb or tw Terabytes or terawords 2 to the 40th, or 1024 gigabytes pb or pw Petabytes or petawords 2 to the 50th, or 1,048,576 gigabytes -
Click
to save the change.
