Cable Schematic Display Options
View the display options for the cable schematic view.
Icon | Name | Description |
Rotate | Rotate the selected item. |
Cross sections | Show / Hide the cable-cross section display. |
Connector spacing | Set the spacing factor between connectors on the cable schematic view. |
Projection | Projection on the XY plane. |
Projection | Projection on the XZ plane. |
Projection | Projection on the YZ plane. |
