A simple example is given to show how to mesh an existing model or modify multiple
variables and remeshing the model.
As an example, Example 1 of the Feko Example Guide will
be meshed using the batch meshing tool
(Dipole_Example.cfx).
Open the Feko terminal.
[Optional] Change the directory to where the file is located.
Note: If the directory is not changed to where the file is located, the path can
be included in the file name.
Launch the batch meshing tool and mesh (without modifying the values of any
variables).
cadfeko_batch Dipole_Example.cfx
Launch the batch meshing tool, modify the variables h and
radius, re-evaluate and remesh the model.
cadfeko_batch Dipole_Example.cfx -#h=lambda/4 -#radius=1.8e-3
