Install Additional Python Packages
Install Python packages using OML and other methods.
Install Using OML
Use the installpythonpackage OML function to install a Python library directly from the Compose interface. You can add information to the existing installpythonpackage documentation as required.
Install Using Other Methods
pip command to install packages from the repository.- Run the Python executable:
- Windows
- <INSTALLATION_ROOT>\common\python\python<version>\win64\python.exe -m pip install <package>
- Linux
- <INSTALLATION_ROOT>/altair/common/python/python<version>/linux64/bin/python3 -m pip install <package>
- For both Windows and Linux, you can also install a pre-compiled binary that's downloaded from other sources rather than installing from an online package, which could require compiling from the source. Resolving dependency issues on Windows can be complicated.
- From the Python packages, download the wheel
package and use the following command to install it:
- Windows
- <INSTALLATION_ROOT>\common\python\python<version>\win64\python.exe -m pip install <path-to-wheel>/package_name.whl
- Linux
- <INSTALLATION_ROOT>/altair/common/python/python<version>/linux64/bin/python3 -m pip install <path-to-wheel>/package_name.whl
Note: If a Python package requires any direct or indirect building of C++/Fortran code, it may not work.
- Install a Python package using the “--user”
option.
- Python packages installed using the “--user” option go to a default location if the PYTHONUSERBASE environment variable is not set. Python packages installed for other applications using “--user” will interfere with Compose if PYTHONUSERBASE is not set.
- To avoid the potential problem, Compose sets
PYTHONUSERBASE to:
<user home directory>/.altair/Compose<version>/hwx/python
- Set PYTHONUSERBASE to <user home directory>/.altair/
Compose<version>/hwx/python before using the
argument “--user” to install packages.
- Windows
- set PYTHONUSERBASE=C:/Users/<userid>/.altair/Compose2022.1/hwx/python
- Linux
- export PYTHONUSERBASE=/home/<userid>/.altair/Compose2022.1/hwx/python
