Global and Configuration Specific Entities
Entities such as frequency, sources, loads and power can be set globally or specified per configuration.
Global
Global refers to entities that are relevant to all configurations.
Tip: Sources defined globally are applicable to standard configurations since sources are not applicable to S-parameter configurations. Sources are not required for characteristic mode configurations, but can be added.
Configuration-specific
Configuration-specific entities are only applicable to a specified configuration. For example, frequency per configuration and sources per configuration. Configurations inherit all global items.
Note: By default, frequency, sources, loads and power are set globally.
