Modifying the Solution Order of Configurations
The Solver solves the configurations in the order in which the configurations are listed in the configuration list, but the order can be changed.
As an example, a configuration is moved up in the configuration list. Similar steps are followed to move the configuration down in the list.
- In the configuration list, select the configuration.
Move the configuration using one of the following workflows:
- From the right-click context menu, select
Move up.
- Press Ctrl++ to use the keyboard shortcut.
