EQUATION
Specifies the equation systems present in the problem.
AcuTrace Command
EQUATION {parameters}
Qualifier
This command has no qualifier.
particle (enumerated) [=massless]
Type of the particle motion equation.
massless
Massless particle equation.
finite_mass
Finite mass particle equation.
stretch (enumerated) [=none]
Type of the stretch equation.
none
No stretch equation present.
standard
Standard stretch equation.
user_equations (list) [={}]
List of user equations to be used.
number_particle_components or num_part_comps (integer) >=0 [=0]
Number of particle components.
The EQUATION command specifies the existence and types of the equation systems and solution fields present in the problem. For example, to specify a problem with particle position using the massless model and stretch, you need:
EQUATION {
   particle = massless
   stretch  = standard
while to use the finite mass model instead, you need:
EQUATION {
   particle = finite_mass
   stretch  = standard
In the massless model, the velocity of a particle always equals the flow velocity at the particle's location. In the finite mass model, the particle velocity does not necessarily equal the flow velocity. Instead, the particles have mass and are subject to forces such as drag and gravity.
The massless particle and stretch equations are:(1)
where D D t denotes the derivative in the particle frame of reference, t is time, x → p is the particle position, u → f is the flow velocity, ∇ u ⇀ f T MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaey4bIe9aa8 HcaeaacaWG1baacaGLrdcadaWgaaWcbaGaamOzaaqabaGcdaahaaWc beqaaiaadsfaaaaaaa@3C53@ is the transpose of the velocity gradient, and l ⇀ p MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaa8Hcaeaaca WGSbaacaGLrdcadaWgaaWcbaGaamiCaaqabaaaaa@39BE@ is the stretch vector.
If the parameter turbulence_trace in the TRACE_PARAMETERS command is set to on, the massless particle equation solved is not the above but instead(2)
where u ⇀ t u r b MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaa8Hcaeaaca WG1baacaGLrdcadaWgaaWcbaGaamiDaiaadwhacaWGYbGaamOyaaqa baaaaa@3CA3@ is a random perturbation to the particle velocity based on the eddy viscosity.
The finite mass particle equations are(3)
where u → p MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaa8Haaeaaca WG1baacaGLxdcadaWgaaWcbaGaamiCaaqabaaaaa@39C5@ is the particle velocity, m p MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyBamaaBa aaleaacaWGWbaabeaaaaa@3809@ is the particle mass, and F → MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaa8Haaeaaca WGgbaacaGLxdcaaaa@3875@ is the sum of the forces acting on the particle. If the parameter turbulence_trace in the TRACE_PARAMETERS command is set to on, then the values of u → f MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaa8Haaeaaca WG1baacaGLxdcadaWgaaWcbaGaamOzaaqabaaaaa@39BB@ used in evaluating F → MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaa8Haaeaaca WGgbaacaGLxdcaaaa@3875@ are replaced by u → f + u → t u r b MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaa8Haaeaaca WG1baacaGLxdcadaWgaaWcbaGaamOzaaqabaGccqGHRaWkdaWhcaqa aiaadwhaaiaawEniamaaBaaaleaacaWG0bGaamyDaiaadkhacaWGIb aabeaaaaa@4152@ . Note that particles are assumed to be spherical of constant (subgrid scale) size.
The particle and stretch equations can be augmented by one or more user equations. The user equations can either be evolution equations of the form(4)
where s ⇀ p MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaa8Hcaeaaca WGZbaacaGLrdcadaWgaaWcbaGaamiCaaqabaaaaa@39C5@ is the set of user-defined particle variables in the current equation, S ⇀ p MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaa8Hcaeaaca WGtbaacaGLrdcadaWgaaWcbaGaamiCaaqabaaaaa@39A5@ is the set of user-defined variables from the other user equations (if any), U ⇀ f MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaa8Hcaeaaca WGvbaacaGLrdcadaWgaaWcbaGaamOzaaqabaaaaa@399D@ is the set of flow variables, and V ⇀ u d f MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaa8Hcaeaaca WGwbaacaGLrdcadaWgaaWcbaGaamyDaiaadsgacaWGMbaabeaaaaa@3B81@ is the set of user equation parameters; or evaluation equations of the form(5)
The user equations present in the problem are specified by the user_equations parameter. Each user equation specified by the user_equations parameter must be defined by a USER_EQUATION command.
For example, evolution equations tparticle and cparticle for particle temperature and composition could be defined. To include these equations in a problem, one could have:
EQUATION {
   user_equations = {tparticle, cparticle}
USER_EQUATION( "tparticle" ) {
   user_function = "usrTparticle"
   num_variables = 1
USER_EQUATION( "cparticle" ) {
   user_function = "usrCparticle"
   num_variables = 2                         # 2 species example
The EQUATION command specifies the existence and types of the equation systems and solution fields present in the problem. The TIME_SEQUENCE and STAGGER commands must then be used to request the solution for the specified equations. For example, to solve for particle position and stretch, you could have:
EQUATION {
   particle = massless
   stretch = standard
TIME_SEQUENCE {
   staggers = { "particle", "stretch" }
STAGGER( "particle" ) {
   equation = particle
STAGGER( "stretch" ) {
   equation = stretch
As with particle and stretch equations, the TIME_SEQUENCE and STAGGER commands must be used to request the solution for the specified user equations. For example, to solve for particle position, temperature, and composition, you could have:
EQUATION {
   particle       = massless
TIME_SEQUENCE {
   staggers       = { "particle", "tparticle", "cparticle"}
   equation = particle
STAGGER( "tparticle" ) {
   equation      = user_equation
   user_equation = "cparticle"
STAGGER( "cparticle" ) {
   user_equation = "tparticle"
   num_variables = 1
   num_variables = 2
If an equation is defined by the EQUATION command, but no active stagger references that equation, the solution field of that equation is unaltered throughout the analysis.
Particle components are a generalization of a marker variable; they can also be considered a generalization of species or composition. When number_particle_components is greater than zero, particle components are initialized in the PARTICLE_SEED command. The values of the particle components are constant in time but they may vary over the particles in the problem according to how they are initialized.
