GAS_KINETIC_MODEL
Specifies a gas kinetic model for the advective_diffusive multifield type.
AcuSolve Command
GAS_KINETIC_MODEL("name") {parameters...}
Qualifier
User-given name.
geometrical_configuration_index (integer) >=0 <=2 [=1]
An integer value indicating the type of molecular configuration. If the value is 0, the molecule is a single atom. If it is 1 the molecule is linear. Finally, if it is 2, the molecule is nonlinear.
Lennard_Jones_potential_well_depth (real) [=97.530]
The Lennard-Jones potential well depth of the gas in Kelvin.
Lennard_Jones_collision_diameter (real) [=3.621]
The Lennard-Jones collision diameter of the gas in Angstroms.
dipole_moment (real) [=0.0]
The dipole moment of the gas in Debye.
Polarizability (real) [=1.760]
The polarizability in cubic Angstroms.
rotational_relaxation_collision_number (real) [=4.0]
The rotational relaxation collision number at 298 Kelvin.
molecular_weight (real) [=0.028013]
Molecular weight of the gas.
This command sets kinetic model molecular parameters for each gas. Gas kinetic model is used to calculate viscosity, conductivity, and mass diffusion coefficients for each model. This model should be referred in MATERIAL_MODEL of the gas. This is an example to set parameters for Nitrogen:
GAS_KINETIC_MODEL( "N2" ) {
    geometrical_configuration_index     = 1
    molecular_weight                    = 0.028013
    Lennard_Jones_potential_well_depth  = 97.530
    Lennard_Jones_collision_diameter    = 3.621
    dipole_moment                       = 0.0
    polarizability                      = 1.760
    rotational_relaxation_collision_number = 4.000
VISCOSITY_MODEL( "N2" ) {
    type                                = gas_kinetic
CONDUCTIVITY_MODEL( "N2" ) {
    type                                = gas_kinetic
    turbulent_prandtl_number            = 0.91
If species_trasport equation is getting solved, gas kinetic diffusivity can be set as:
DIFFUSIVITY_MODEL( "N2" ) {
    type                                = gas_kinetic
If multi_field equation type advective-diffusive is getting solved, gas kinetic diffusivity should be set using FIELD_INTERACTION_MODEL:
FIELD_INTERACTION_MODEL( "Mixture" ) {
    type                                = advective_diffusive
    diffusion_matrix_type               = gas_kinetic
