Alternative Command Organization
In the rest of this manual the commands are grouped into general categories and placed into chapters. In order to make a particular command functionality easier to find, an alternative categorization is presented. Each command may appear in more than one category.
Nodal Data
COORDINATE
NODAL_BOUNDARY_CONDITION
RESTART_OUTPUT
NODAL_OUTPUT
NODAL_RESIDUAL_OUTPUT
Continuum Element Data
ELEMENT_SET
FAN_COMPONENT
HEAT_EXCHANGER_COMPONENT
REFERENCE_FRAME
ELEMENT_OUTPUT
CAA_OUTPUT
CAA_ELEMENT_OUTPUT
FWH_OUTPUT
FWH_SURFACE_OUTPUT
Surface Data
FAN_COMPONENT
ELEMENT_BOUNDARY_CONDITION
SIMPLE_BOUNDARY_CONDITION
INTERFACE_SURFACE
GUIDE_SURFACE
EXTERNAL_CODE_SURFACE
SURFACE_INTEGRATED_CONDITION
FREE_SURFACE
TURBULENCE_WALL
PARTICLE_SURFACE
RADIATION_SURFACE
SOLAR_RADIATION_SURFACE
CAA_SURFACE_OUTPUT
FWH_SURFACE_OUTPUT
Boundary Conditions
PERIODIC_BOUNDARY_CONDITION
ELEMENT_SET
FREE_SURFACE
RADIATION_SURFACE
Output
RESTART_OUTPUT
NODAL_OUTPUT
TIME_AVERAGE_OUTPUT
TIME_HISTORY_OUTPUT
SURFACE_OUTPUT
ELEMENT_OUTPUT
FAN_COMPONENT
RADIATION_SURFACE
DERIVED_QUANTITY_OUTPUT
RUNNING_AVERAGE_OUTPUT
CAA_ELEMENT_OUTPUT
CAA_OUTPUT
CAA_SURFACE_OUTPUT
ERROR_ESTIMATOR_OUTPUT
EXTERNAL_OUTPUT
FWH_OUTPUT
FWH_SURFACE_OUTPUT
Restart
RESTART_OUTPUT
RESTART
Radiation
EQUATION
RADIATION
EMISSIVITY_MODEL
RADIATION_SURFACE
SOLAR_RADIATION
SOLAR_RADIATION_MODEL
Turbulence Modeling
EQUATION
TIME_SEQUENCE
STAGGER
TURBULENCE_WALL
Component Models
FAN_COMPONENT
Material Models
DENSITY_MODEL
SPECIFIC_HEAT_MODEL
VISCOSITY_MODEL
CONDUCTIVITY_MODEL
DIFFUSIVITY_MODEL
POROSITY_MODEL
EMISSIVITY_MODEL
SURFACE_TENSION_MODEL
CONTACT_ANGLE_MODEL
VISCOELASTIC_MODEL
Fluid-Solid Interaction
MESH_MOTION
FLEXIBLE_BODY
EXTERNAL_CODE
Body Forces
GRAVITY
REFERENCE_FRAME
MASS_HEAT_SOURCE
VOLUME_HEAT_SOURCE
MASS_SPECIES_SOURCE
VOLUME_SPECIES_SOURCE
BODY_FORCE
LINE_SOURCE
Solution Strategy
AUTO_SOLUTION_STRATEGY
ANALYSIS
TIME_SEQUENCE
STAGGER
TIME_ INCREMENT
CONVERGENCE_CHECK_PARAMETERS
TIME_INTEGRATION
LINEAR_SOLVER_PARAMETERS
PARTICLE_TRACE
Transient/Steady Analysis
ANALYSIS
TIME_SEQUENCE
STAGGER
TIME_ INCREMENT
TIME_INTEGRATION
Auxiliary Functions
USER_GLOBAL_DATA
MULTIPLIER_FUNCTION
MESH_MOTION
GUIDE_SURFACE
ASSIGN
