NODAL_BOUNDARY_CONDITION
Specifies boundary conditions for a solution field on a set of nodes.
AcuSolve Command
NODAL_BOUNDARY_CONDITION("name") {parameters...}
Qualifier
User-given name.
- variable or var (enumerated) [no default]
- Boundary condition variable.
- x_velocity or xvel
- X-component of velocity.
- y_velocity or yvel
- U-component of velocity.
- z_velocity or zvel
- Z-component of velocity.
- direction_velocity or dvel
- A velocity component in an arbitrary direction. Requires direction_type.
- pressure or pres
- Pressure.
- temperature or temp
- Temperature.
- relative_humidity or relHum
- Relative humidity.
- dewpoint_temperature or dewpoint
- Dewpoint temperature.
- electric_potential
- Electric potential value. A value of zero represents a ground voltage.
- species_1 or spec1
- Species 1.
- species_2 or spec2
- Species 2.
- species_3 or spec3
- Species 3.
- species_4 or spec4
- Species 4.
- species_5 or spec5
- Species 5.
- species_6 or spec6
- Species 6.
- species_7 or spec7
- Species 7.
- species_8 or spec8
- Species 8.
- species_9 or spec9
- Species 9.
- eddy_viscosity or eddy
- Turbulence kinematic eddy viscosity.
- kinetic_energy or tke
- Turbulence kinetic energy.
- eddy_frequency or tomega
- Turbulence eddy frequency.
- eddy_time or ttau
- Turbulence eddy time.
- dissipation_rate or teps
- Turbulence dissipation rate.
- intermittency or tintc
- Transition intermittency.
- transition_re_theta or treth
- Transition Re-Theta
- viscoelastic_xx_stress or xxvest
- x-x component of the viscoelastic stress.
- viscoelastic_yy_stress or yyvest
- y-y component of the viscoelastic stress.
- viscoelastic_zz_stress or zzvest
- z-z component of the viscoelastic stress.
- viscoelastic_xy_stress or xyvest
- x-y component of the viscoelastic stress.
- viscoelastic_yz_stress or yzvest
- y-z component of the viscoelastic stress.
- viscoelastic_zx_stress or zxvest
- z-x component of the viscoelastic stress.
- field
- Volume fraction of field in multi field for levelset and algebraic Eulerian problems or mass fraction of field in multi field for the humid air model.
- mesh_x_displacement or mesh_xdisp
- X-component of mesh displacement.
- mesh_y_displacement or mesh_ydisp
- Y-component of mesh displacement.
- mesh_z_displacement or mesh_zdisp
- Z-component of mesh displacement.
- mesh_direction_displacement or mesh_ddisp
- A mesh displacement component in an arbitrary direction. Requires direction_type.
- mesh_x_velocity or mesh_xvel
- X-component of mesh velocity.
- mesh_y_velocity or mesh_yvel
- Y-component of mesh velocity.
- mesh_z_velocity or mesh_zvel
- Z-component of mesh velocity.
- mesh_direction_velocity or mesh_dvel
- A mesh velocity component in an arbitrary direction. Requires direction_type.
- precedence (integer) [=1]
- Precedence of this boundary condition set with respect to other sets. The set with the highest value has precedence.
- type (enumerated) [=zero]
- Type of the boundary condition.
- zero
- Zero for the set.
- constant or const
- Constant value. Requires constant_value.
- nodal
- Nodal values. Requires nodal_values.
- nodal_time_series
- Time series for each node. Requires nodal_values and times_series.
- piecewise_linear or linear
- Piecewise linear curve fit. Requires curve_fit_values and curve_fit_variable.
- cubic_spline or spline
- Cubic spline curve fit. Requires curve_fit_values and curve_fit_variable.
- user_function or user
- User-defined function. Requires user_function, user_values and user_strings.
- userscattered_data
- Spatially interpolate from data. Requires scattered_data, scattered_data_origin and scattered_data_axes.
- scattered_data_time_series
- Spatially and temporally interpolate from data. Requires scattered_data, scattered_data_origin, scattered_data_axes, and times_series.
- external_file
- Read values dynamically from an external file. Requires external_file, external_file_evaluation and external_file_nodal_offset.
- match_mesh_velocity
- Set equal to the corresponding component of mesh velocity. Used with x_velocity, y_velocity, z_velocity and direction_velocity variables.
- mesh_motion
- Mesh displacement given by MESH_MOTION command. Requires mesh_motion. Used with mesh_x_displacement, mesh_y_displacement and mesh_z_displacement variables.
- flexible_body
- Mesh displacement or velocity given by FLEXIBLE_BODY command. Requires flexible_body and nodal_modes. Used with mesh displacement and velocity variables.
- design_variables
- User-given name of the design optimization variable.
- guide_surface
- Allows mesh to slip on a given surface. Requires guide_surface. Used with x_velocity, y_velocity, z_velocity, direction_velocity and mesh_direction_displacement variables.
- external_code
- Mesh displacement given by an external solid/structural code. Used with mesh_x_displacement, mesh_y_displacement, mesh_z_displacement and mesh_direction_displacement variables.
- nodes (array) [no default]
- List of nodal points in this set.
- constant_value or value (real) [=0]
- Constant value of the boundary condition. Used with constant type.
- field (real) [no default]
- Value of the boundary condition for field. Used with variable field.
- nodal_values or values (array) [no default]
- Array of nodes (first column) and data values. Used with nodal and nodal_time_series types.
- curve_fit_values or curve_values (array) [={0,0}]
- A two-column array of independent-variable/boundary-condition data values. Used with piecewise_linear and cubic_spline types.
- curve_fit_variable or curve_var (enumerated) [=temperature]
- Independent variable of the curve fit. Used with piecewise_linear and
cubic_spline types.
- x_coordinate or xcrd
- X-component of coordinates.
- y_coordinate or ycrd
- Y-component of coordinates.
- z_coordinate or zcrd
- Z-component of coordinates.
- x_reference_coordinate or xrefcrd
- X-component of reference coordinates.
- y_reference_coordinate or yrefcrd
- Y-component of reference coordinates.
- z_reference_coordinate or zrefcrd
- Z-component of reference coordinates.
- velocity_magnitude or vel_mag
- Velocity magnitude.
- pressure or pres
- Pressure.
- Temperature.
- relative_humidity
- eddy_frequency
- Species 1.
- Species 2.
- Species 3.
- Species 4.
- Species 5.
- Species 6.
- Species 7.
- Species 8.
- Species 9.
- mesh_displacement_magnitude or mesh_disp_mag
- Mesh displacement magnitude.
- mesh_velocity_magnitude or mesh_vel_mag
- Mesh velocity magnitude.
- user_function or user (string) [no default]
- Name of the user-defined function. Used with user_function type.
- user_values (array) [={}]
- Array of values to be passed to the user-defined function. Used with user_function type.
- user_strings (list) [={}]
- Array of strings to be passed to the user-defined function. Used with user_function type.
- user_nodal_values (array) [={}]
- Array of data values (starting with second column) for each node (first column) to be passed to the user-defined function. Used with user_function type.
- scattered_data (array) [no default]
- Array of xyz coordinates (first three columns] and data values. Used with scattered_data and scattered_data_time_series types.
- scattered_data_origin (array) [={0,0,0}]
- Origin for transformation of scattered_data coordinates to global coordinates. Used with scattered_data and scattered_data_time_series types.
- scattered_data_axes (array) [={1,0,0;0,1,0;0,0,1}]
- Axes for transformation of scattered_data coordinates to global coordinates. Used with scattered_data and scattered_data_time_series types.
- external_file (string) [no default]
- User-given file name referencing the file containing boundary condition data. The file is in local binary format. Used with external_file type.
- external_file_evaluation (enumerated) [=once_per_timestep]
- Frequency of reading the external file. Used with external_file type.
- once_per_timestep or step
- Once per time step.
- external_file_nodal_offset (array) [no default]
- Two-column array giving the node and the byte offset of the datum of each node for reading the external file. Used with external_file type.
- auxiliary_nodes (array) [no default]
- Array of auxiliary nodes (starting with second column) for each node (first column) to be passed to the user defined function. Used with user_function type.
- reference_frame (string) [=none]
- User-given name of the reference frame for transforming a velocity boundary condition. If none, or if variable is not a velocity component, no transformation takes place.
- multiplier_function (string) [=none]
- User-given name of the multiplier function for scaling the boundary condition. If none, no scaling is performed.
- mesh_motion (string) [=none]
- User-given name of the MESH_MOTION command for specifying (mesh_motion type) or scaling (other types) a mesh displacement boundary condition. If none, or if variable is not a mesh displacement component, no scaling is performed. none is not supported with mesh_motion type.
- flexible_body (string) [no default]
- User-given name of the FLEXIBLE_BODY command for specifying a mesh displacement or velocity boundary condition. Used with flexible_body type.
- guide_surface (string) [no default]
- User-given name of the GUIDE_SURFACE command for specifying a velocity or mesh displacement boundary condition. Used with guide_surface type.
- nodal_modes (array) [no default]
- Array of node number (first column) and eigenvector values (last num_modes columns, where num_modes is given by the FLEXIBLE_BODY command referenced by flexible_body). Used with flexible_body type.
- time_series (array) [={0}]
- Array of time values. Used with nodal_time_series and scattered_data_time_series types.
- time_series_variable (enumerated) [=time]
- Independent variable for time series. Used with nodal_time_series and
- time
- Time
- cyclic_time
- Time cycled over a period. Requires time_series_cyclic_period.
- User-given name of the multiplier function that replaces time. Requires time_series_variable_multiplier_function.
- time_series_cyclic_period (real) >=0 [=1]
- Value of the time period. Zero denotes an infinite period. Used with cyclic_time time series variable.
- time_series_variable_multiplier_function (string) [=none]
- User-given name of the multiplier function for the independent variable of the time series. If none, the independent variable is zero. Used with multiplier_function time series variable.
- coupling_type (enumerated) [=structural]
- Manner in which the nodes are coupled to an external code. Used with
type=external_code.
- structural
- Nodes are coupled with either a line or surface element set in the external.
- line
- Nodes are coupled with a line element set in the external code.
- surface
- Nodes are coupled with a surface element set in the external code.
- rigid_body
- Nodes are coupled with a rigid body in the external code.
- rigid_body_name (array) [no default]
- Name of the rigid body the nodal boundary condition is coupled with. Used with mesh displacement and velocity variables, type=external_code and coupling_type=rigid_body.
- external_code_tags (list) [={}]
- Array of strings to be passed to the external code for identifying surface associations for the purpose of boundary condition assignment. Used with mesh displacement and velocity variables and when type=external_code. Used with coupling_type of structural, line, or surface. When this option is specified, the associativity of a given node in the AcuSolve model is restricted based on this mapping and not a simple projection of the external code coordinates onto the AcuSolve surfaces.
- direction_type or dir_type (enumerated) [=constant]
- Type of the direction vector. Used with direction_velocity
variable.
- constant or const
- Constant direction. Requires constant_direction.
- nodal
- Nodal direction. Requires nodal_directions.
- normal
- Direction is normal to the boundary. Direction is computed automatically.
- constant_direction (array) [={1,0,0}]
- Constant direction vector specified in the global xyz coordinate system. Direction is normalized before use. Used with constant direction type.
- nodal_directions (array) [no default]
- Nodal direction vector. Directions are normalized before use. Used with nodal direction type.
- active_type (enumerated) [=all]
- Type of the active flag. Determines which nodes in this set will have this
boundary condition imposed.
- all
- All nodes in this set are active.
- none
- No node in this set is active.
- inflow or in
- Only nodes where the flow is into the fluid domain are active.
- Active nodes determined by a user-defined function. Requires active_user_function, active_user_values and active_user_strings.
- no_outflow
- Only nodes that where there is no outflow are active.
- no_interface
- Only nodes that are not on an interface surface or do not find a contact surface of an appropriate medium are active.
- far_field
- Only nodes that have a velocity boundary condition vector that is entering into the volume are active.
- active_user_function (string) [no default]
- Name of the user-defined function for the active flag. Used with user_function active type.
- active_user_values (array) [={}]
- Array of values to be passed to the active flag user-defined function. Used with user_function active type.
- active_user_strings (list) [={}]
- Array of strings to be passed to the active flag user-defined function. Used with user_function active type.
- synthetic_turbulence (boolean) (=off)
- Flag specifying whether to activate the synthetic turbulence feature at inflow, with velocity or atmospheric inflow type. This command is only activated when synthetic_turbulence_input_type in turbulence_model_parameters is set to k_omega (or k_epsilon).
NODAL_BOUNDARY_CONDITION( "constant BC on inflow x-velocity" ) {
variable = x_velocity
type = constant
nodes = { 1 ;
3 ;
6 ; }
constant_value = 12.5
defines nodal boundary conditions on the x-component of velocity for global nodes one, three and six. The boundary condition is a constant value of 12.5 for all three nodes.
The variable and nodes parameters are mandatory. variable specifies the solution field to which the boundary condition applies. If the problem does not solve for such a variable (see the STAGGER command), the boundary condition is ignored. nodes is a single-column array containing a list of node numbers. Node numbers must be valid numbers, as given by the COORDINATE command. Duplicate nodes are not allowed in a single set. This means that to specify two or more boundary conditions on the same variable (such as direction_velocity) and on the same node, multiple NODAL_BOUNDARY_CONDITION commands must be used.
1
3
6
NODAL_BOUDARY_CONDITION( "constant BC on inflow x-velocity" ) {
type = constant
nodes = Read( "inflow.nbc" )
NODAL_BOUNDARY_CONDITION( "Inflow field" ) {
nodes = Read( "Inflow.quad4.nbc" )
variable = "field"
field = "Air"
type = constant
precedence = 2
constant_value = 1
active_type = all
FIELD( "Air" ) {
material_model = "Air"
If more than one nodal boundary condition is specified for a given variable on a given node, then the precedence parameter is used to determine which boundary condition to satisfy. The boundary condition set with the highest value of precedence takes precedence. If two or more boundary conditions have the same highest value, then the one with value of zero takes precedence. For the purpose of this evaluation, boundary conditions of types piecewise_linear, cubic_spline, user_function, and mesh_motion are assumed nonzero. Finally, if the zero condition is ambiguous, the last boundary condition set specified is used. For vector variables, such as velocity, the precedence is determined collectively on all components of the variable. For example, if the direction of a direction_velocity boundary condition coincides with the x-axis and there is also an x_velocity boundary condition on the same node, the above precedence rule is used to determine which boundary condition to satisfy.
A constant boundary condition type applies the same boundary condition on all nodes in the set, as in the above example.
NODAL_BOUNDARY_CONDITION( "zero BC on inflow y-velocity" ) {
variable = y_velocity
type = zero
NODAL_BOUNDARY_CONDITION( "nodal BC on inflow x-velocity" ) {
type = nodal
nodes = { 1 ;
3 ;
6 ; }
nodal_values = { 1, 0 ;
3, 1 ;
6, 2 ; }
The nodal_values parameter is a two-column array corresponding to the node number and boundary condition value. The node numbers must match those given by the nodes parameter. No node may be missing.
1 0
3 1
6 2
type = nodal
nodal_values = Read( "inflow.bcu" )
NODAL_BOUNDARY_CONDITION( "time-dependent nodal BC on inflow x-velocity" ) {
type = nodal_time_series
nodal_values = { 1, 0., 0.1, 0.2, 0.5 ;
3, 1., 1.2, 1.5, 1.8 ;
6, 2., 2.3, 2.6, 2.9 ; }
time_series = { 0., 0.5, 1.0, 1.5 }
1 0. 0.1 0.2 0.5
3 1. 1.2 1.5 1.8
6 2. 2.3 2.6 2.9
0. 0.5 1.0 1.5
time_series = Read( "inflow.time" )
NODAL_BOUNDARY_CONDITION( "time-periodic nodal BC on inflow x-velocity" ) {
time_series_variable = cyclic_time
time_series_cyclic_period = 2
time_series_variable = multiplier_function
time_series_variable_multiplier_function = "ramped time"
MULTIPLIER_FUNCTION( "ramped time" ) {
type = piecewise_linear
curve_fit_values { 0, 0 ;
0.1, 0.01 ;
0.2, 0.04 ;
0.3, 0.09 ;
0.4, 0.16 ;
0.5, 0.25 ;
10.5, 10.25 ; }
curve_fit_variable = time
This multiplier function has the effect of "slowing down" time during the first 0.5 units of time. Such functions are often used to prevent poor physical or numerical behavior caused by the sudden imposition of a boundary condition. Note that the multiplier function specified by time_series_variable_multiplier_function is independent of the one specified by multiplier_function, which may be given as well.
NODAL_BOUNDARY_CONDITION( "curve fit BC on inflow x-velocity" ) {
type = cubic_spline
nodes = { 1 ; 3 ; 6 ; }
curve_fit_values = { -1, 0.0 ; 0, 2.5 ; 1, 0.0 ; }
curve_fit_variable = y_coordinate
defines an x-velocity boundary condition as a function of the y-coordinate. Note that in this example you get a parabolic velocity profile centered at y = 0, with a width of 2 and a center-line magnitude of 2.5. The curve_fit_values parameter is a two-column array corresponding to the independent variable and the boundary condition values. The independent variable values must be in ascending order. The limit point values of the curve fit are used when curve_fit_variable falls outside of the curve fit limits.
-1 0.0
0 2.5
1 0.0
type = cubic_spline
curve_fit_values = Read( "inflow.bcu.fit" )
A nodal boundary condition of user_function type may be used to model more complex behaviors; see the AcuSolve User-Defined Functions Guide for a detailed description of user-defined functions.
NODAL_BOUNDARY_CONDITION( "UDF BC on inflow x-velocity" ) {
type = user_funtion
user_function = "usrNodalBcExample"
user_values = { 0, # y-center 0, # z-center 1, # radius 1 } # max velocity
#include "acusim.h"
#include "udf.h"
UDF_PROTOTYPE( usrNodalBcExample ) ; /* function prototype*/
Void usrNodalBcExample (
UdfHd udfHd, /* Opaque handle for accessing data */
Real* outVec, /* Output vector */
Integer nItems, /* Number of BC nodes */
Integer vecDim /* = 1 */
Integer node ; /* a node counter */
Real radius ; /* pipe radius */
Real scale ; /* scaling factor */
Real ve10 ; /* velocity at center line */
Real y ; /* y-location */
Real yCenter ; /* y-coordinates of inflow center */
Real z ; /* z-location */
Real zCenter ; /* y-coordinates of inflow center */
Real crd ; /* coordinates */
Real usrVals ; /* user values */
Real xCrd ; /* x-coordinates */
Real yCrd ; /* y-coordinates */
Real zCrd ; /* z-coordinates */
udfCheckNumUsrVals( udfHd, 4 ) ; /* check for error */
usrVals = udfGetUsrVals( udfHd ) ; /* get the user vals */
yCenter = usrVals[0] ; /* get y-center */
zCenter = usrVals[1] ; /* get z-center */
radius = usrVals[2] ; /* get pipe radius */
vel0 = usrVals[3] ; /* get max velocity */
scale = 1 / ( radius * radius ) /* for convenience */
crd = udfGetNbcCrd( udfHd ) ; /* get the coord. */
xCrd = &crd[0*nItems] ; /* localize x-coord. */
yCrd = &crd[1*nItems] ; /* localize y-coord. */
zCrd = &crd[2*nItems] ; /* localize z-coord. */
for ( node = 0 ; node < nItems ; node++ ) {
y = yCrd[node] - yCenter ;
z = zCrd[node] - zCenter ;
outVec[node] = vel0 * ( 1 - scale * ( y*y + z*z ) ) ;
} /* end of usrNodalBcExample() */
The dimension of the returned boundary condition vector, outVec, is the number of nodes.
NODAL_BOUNDARY_CONDITION( "BC based on other nodes" ) {
type = user_funtion
auxiliary_nodes = { 1, 101, 201, 301 ;... }
In the above example, the auxiliary nodes of node one are 101, 201 and 301.
NODAL_BOUNDARY_CONDITION( "BC with individual coefs" ) {
type = user_funtion
user_values = { 1.0, 2.0, 3.0 }
user_nodal_values = { 1, 4.0, 5.0 ;... }
Using both auxiliary_nodes and user_nodal_values enables the computation of interpolated and projected data inside of user functions.
NODAL_BOUNDARY_CONDITION( "experimental data for inflow temperature" ) {
nodes = Read( "channel.inflow.nbc" )
variable = temperature
type = scattered_data
scattered_data = { 0.0, 0.0,
0.0, 100.0 ;
2.0, 0.0, 0.0, 102.0 ;
0.0, 1.0, 0.0, 105.0 ;
1.0, 1.5, 0.0, 107.0 ;
2.0, 1.0, 0.0, 110.0 ; }
scattered_data_origin = { 0, -10, 0 }
scattered_data_axes = { 0, 1, 0 ;
0, 0, 1 ;
1, 0, 0 ; }
This command defines a temperature boundary condition from a set of scattered data. Here, the data was measured in the xy-plane, while the inflow plane of the model is parallel to the yz-plane and shifted by -10 in the y axis.
0.0 0.0 0.0 100.0
2.0 0.0 0.0 102.0
0.0 1.0 0.0 105.0
1.0 1.5 0.0 107.0
2.0 1.0 0.0 110.0
scattered_data = Read( "measured.temp.dat" )
0, 0, 1 ;
1, 0, 0 ; }
In general, the user coordinates are first transformed to the global coordinate system. Then a plane is fitted to these points and all the points are projected to this plane. In the present example the data is already planar so there is no approximation. The points are triangulated and a 2D mesh is constructed. Each boundary condition node is then projected to this mesh and the data linearly interpolated to produce the boundary condition value. If the projection falls outside of the constructed mesh, the closest edge of the mesh is found and linear interpolation is performed along the edge. This algorithm works well for planar or nearly planar user data. If the data are far from planar, the results may be unpredictable. The algorithm also guarantees all boundary condition values are bounded by the user data. The disadvantage is that the interpolation is faceted and not smooth.
NODAL_BOUNDARY_CONDITION( "time series experimental data for inflow temp" ) {
type = scattered_data_time_series
scattered_data = { 0.0, 0.0, 0.0, 100.0, 110.0, 120.0 ;
2.0, 0.0, 0.0, 102.0, 112.0, 122.0 ;
0.0, 1.0, 0.0, 105.0, 115.0, 125.0 ;
1.0, 1.5, 0.0, 107.0, 117.0, 127.0 ;
2.0, 1.0, 0.0, 110.0, 120.0, 130.0 ; }
time_series = { 0.0, 0.5, 1.0 }
0, 0, 1 ;
1, 0, 0 ; }
The parameters time_series_variable, time_series_cyclic_period, and time_series_variable_multiplier_function may be used with scattered_data_time_series type in exactly the same way as they are used with nodal_time_series type above.
NODAL_BOUNDARY_CONDITION( "inflow x-vel" ) {
nodes = Read("inflow.nbc")
type = external_file
external_file = "inflow.exf"
external_file_nodal_offset = Read("inflow.loc")
external_file_evaluation = once_per_time_step
At the beginning of each time step, the boundary condition values for nodes in "inflow.nbc" and variable x_velocity are read from "inflow.exf". The file is deleted after it is read by all nodal boundary condition commands referencing this file. This deletion may be used as a signal that the next file may be written. The appearance of the file signals AcuSolve that the data is ready for reading. An error is issued and AcuSolve exits if the file does not appear within 600 seconds. In order to avoid reading incomplete data, it is recommended that a temporary file be used to hold the data which is then renamed appropriately after it is closed. The values are read as native 8-byte binary floating point numbers. The byte offset for each node (from the beginning of the file) is specified in the "inflow.loc" file. This is a 2-column file, where the first column contains the nodes given in nodes parameter ("inflow.nbc" in this case) and the second column specifies the byte offset, typically set to 0, 8, 16, 24, and so on.
By default, all boundary conditions are specified with respect to the fixed (or "laboratory") reference frame. If the REFERENCE_FRAME command is used to define the rotational body forces (this is recommended, as opposed to using the ROTATION_FORCE command), then the velocity boundary conditions on a rotating wall are non-trivial. However, the reference_frame parameter provides a convenient way of specifying these conditions. Instead of the fixed frame, velocity boundary conditions are applied in the given frame. In many cases, a zero type can then be used. See the REFERENCE_FRAME command for more details and an example. The reference_frame parameter has no effect on variables other than velocity components.
type = user_function
0, # z-center
1, # radius
1 } # max velocity
multiplier_funtion = "ramped"
MULTIPLIER_FUNCTION( "ramped" ) {
curve-fit_values = { 0, 0 ; 10, 1 }
NODAL_BOUNDARY_CONDITION( "accelerating wall" ) {
variable = y_mesh_displacement
type = constant
constant_value = 5.
multiplier_function = "accelerate"
MULTIPLIER_FUNCTION( "accelerate" ) {
type = cubic_spine
curve_fit_values = { 0, .0 ;
1, .1 ;
2, .4 ;
3, .9 ; }
NODAL_BOUNDARY_CONDITION( "match y velocity" ) {
type = match_mesh_velocity
Note that the match_mesh_velocity type may only be used with velocity-component variables and may not be combined with a multiplier function.
NODAL_BOUNDARY_CONDITION( "buffer region for mesh displacement" ) {
variable = mesh_x_displacement
nodes = Read( "buffer.nbc" ) # all nodes in -10 < x <10
curve_fit_values = { -10, 0.0 ; -1, 1.0 ; 1, 1.0 ; 10, 0.0 }
curve_fit_variable = x_reference_coordinate
mesh_motion = "moving body"
MESH_MOTION( "moving body" ) {
type = rigid_body
If the rigid body is originally within -1 < x < 1 then the mesh in this area follows the rigid body without distortion. The distortion takes place in the larger buffer area away from the body and smoothly ramps down to zero at x = ±10. Note that this strategy also allows the use of mesh=specified in the EQUATION command and thus avoids solving an ALE equation.
Fluid-structure interaction (FSI) problems use the flexible_body type in a manner similar to the rigid_body type. The flexible_body parameter references a FLEXIBLE_BODY command that is used to drive either a mesh displacement or velocity boundary condition here, depending on the modeling type specified by the equation parameter of FLEXIBLE_BODY. The eigenvectors required by a FSI calculation are given by nodal_modes here. See the FLEXIBLE_BODY command for a detailed description of FSI modeling and an example.
MESH_MOTION( "boat motion" ) {
type = rigid_body_dynamic
rigid_body_mass = 100
rigid_body_surface_outputs = { "ocean: boat hull" }
SURFACE_OUTPUT( "ocean: boat hull" ) {
surfaces = Read( "ocean.hull.ebc" )
shape = three_node_triangle
element_set = "ocean"
GUIDE_SURFACE( "moving boat surface" ) {
element_set = "boat"
mesh_motion = "boat motion"
NODAL_BOUNDARY_CONDITION( "slip condition for mesh" ) {
variable = mesh_direction_displacement
type = guide_surface
nodes = Read( "boat.wall.nbc" )
guide_surface = "moving boat surface"
NODAL_BOUNDARY_CONDITION( "no-slip condition for x-velocity" ) {
NODAL_BOUNDARY_CONDITION( "no-slip condition for y-velocity" ) {
NODAL_BOUNDARY_CONDITION( "no-slip condition for z-velocity" ) {
variable = z_velocity
NODAL_BOUNDARY_CONDITION( "match normal velocity to mesh" ) {
variable = direction_velocity
Note that four boundary conditions are given for the velocity. The direction_velocity condition is necessary to conserve mass, but using a match_mesh_velocity type for the velocity vector would be wrong since the mesh slips and the velocity does not. This apparent over-specification is resolved internally by giving the direction_velocity condition a higher precedence. Effectively, the velocity produced by the x, y, and z conditions is projected to the nearest velocity that satisfies conservation of mass. A slip velocity condition is obtained by removing the three commands for the x, y, and z velocity components.
NODAL_BOUNDARY_CONDITION( "match normal mesh displacement to solid" ) {
type = external_code
nodes = Read( "external.nbc" )
external_code_tags = { "Surface 1"; }
coupling_type = surface
Assuming the specified nodes are not on the external surface, this command constrains the nodes to remain a constant distance away from the deforming solid, but allows them to slide relative to the solid. In this case, the external_code_tags option was used to tell the external code to force these nodes to move with a surface tagged as "Surface 1". Note that this parameter is optional and is only necessary when the standard mapping procedure between fluid and solid codes produces an ambiguous surface association for the nodes of the fluid. If all three components of the mesh displacement are specified (in three commands) then the nodes will move with the solid. In both cases the point on the solid surface closest to the given node is used to determine the mesh motion and the normal direction.
NODAL_BOUNDARY_CONDITION( "slip velocity -- constant direction" ) {
type = zero
nodes = Read( "wall.nbc" )
direction_type = constant
constant_direction = { 1, 1, 0 }
imposes a zero boundary condition on the (1,1,0) component of velocity of all nodes given in the "wall.nbc" file. The vector constant_direction specifies the direction in the global xyz coordinate system. The direction vector is normalized before use.
The direction type of constant_direction specifies the same direction vector for all nodes in the boundary condition set, as in the above example.
NODAL_BOUNDARY_CONDITION( "slip velocity -- nodal direction" ) {
type = zero
direction_type = nodal
nodal_directions = { 1, 1, 1, 1 ;
3, 1, 1, 0 ;
6, 1, 1,-1 ; }
The nodal_directions parameter is a four-column array corresponding to node numbers and the x, y, and z components of the direction vectors. The node numbers must match those given by the nodes parameter. No node may be missing. All direction vectors are normalized before use.
1 1 1 1
3 1 1 0
6 1 1 -1
type = zero
nodal_directions = Read( "slip.dir" )
NODAL_BOUNDARY_CONDITION( "slip velocity -- normal direction" ) {
type = zero
nodes = { 1 ;
3 ;
6 ; }
direction_type = normal
computes the normal direction to nodes one, three, and six, and imposes a zero velocity in that normal direction.
NODAL_BOUNDARY_CONDITION( "wall x-velocity" ) {
NODAL_BOUNDARY_CONDITION( "wall y-velocity" ) {
NODAL_BOUNDARY_CONDITION( "wall z-velocity" ) {
RESTART {}
active_type = none
active_type = none
RUN {}
An inflow active type is typically used to stabilize outflow boundary conditions. For those nodes in the set where the normal velocity is out of the fluid domain (that is, the desired situation for outflow boundaries) then the boundary condition is turned off. However, for nodes with reverse flow (normal velocity into the fluid domain), the boundary condition is activated. This is particularly useful for scalar variables and both components of the tangential velocity, which would otherwise be undefined at reverse flow nodes and be potential sources of instability. A no_outflow active type is the same as inflow except nodes with zero normal velocity are also activated.
A user_function active type may be used to model more complex behaviors; see the AcuSolve User-Defined Functions Guide for a detailed description of user-defined functions. Values of the active flag between zero and one are allowed; such values are used to linearly interpolate between the previous value of the variable and its given boundary condition, with the result imposed as the actual boundary condition.
![](../../images/acusolve/nodal_boundary_condition_acusolve_com_reff1.png)
NODAL_BOUNDARY_CONDITION( "UDF moving wall for x-velocity" ) {
type = constant
constant_value = 5
nodes = Read( "moving_wall.nbc" )
active_type = user_function
active_user_function = "usrActiveFlagExample"
active_user_values = { -100, # initial wall location
5, # wall speed
0.1 } # mushy interval
#include "acusim.h"
#include "udf.h"
UDF_PROTOTYPE( usrActiveFlagExample ) ; /* function prototype */
Void usrActiveFlagExample (
Real x0 ; /* initial location of wall */
Real speed ; /* speed of wall */
Real mushy ; /* mushy interval */
Real xWall ; /* location of wall */
Real time ; /* time */
Real delta_x ; /* distance from wall */
Real* crd ; /* coordinates */
Real* usrVals ; /* user values */
Real* xCrd ; /* x-coordinates */
udfCheckNumUsrVals( udfHd, 3 ) ; /* check for error */
time = udfGetTime( udfHd ) ; /* get the time */
x0 = usrVals[0] ; /* get initial loc */
speed = usrVals[1] ; /* get speed */
mushy = usrVals[2] ; /* get mushy interval */
xWall = x0 + speed * time ; /* location of wall */
delta_x = xCrd[node] - xWall ;
if ( delta_x >= mushy ) {
outVec[node] = 0 ;
} else if ( delta_x <= 0 ) {
outVec[node] = 1 ;
} else {
outVec[node] = 1. - delta_x / mushy ;
} /* end of usrActiveFlagExample() */
The dimension of the returned active flag vector, outVec, is the number of nodes.
- The node is not in any INTERFACE_SURFACE set; active flag = 1.
- The node is a part of an INTERFACE_SURFACE set, but it does not find a contact surface; active flag = 1.
- The node finds a contact surface of fluid medium; active flag = 0.
- The node finds a contact surface of solid/shell medium, and variable is defined on the solid/shell side (currently only temperature); active flag = 0.
- The node finds a contact surface of solid/shell medium, and variable is not defined on the solid/shell side (that is, it is not temperature; active flag = 1.
The pressure may be imposed either strongly via the NODAL_BOUNDARY_CONDITION command or weakly via the ELEMENT_BOUNDARY_CONDITION command. The latter command should be used in all cases, except when a boundary condition is imposed on the normal component of velocity on all boundary nodes (this includes defining boundary conditions on all three velocity components). In this case pressure is defined up to a constant, and it is advisable to specify pressure at one and only one nodal point to define that constant.
NODAL_BOUNDARY_CONDITION( "some x-velocity" ) {
Synthetic_turbulence = on
Note that synthetic_turbulence is normally set to on for all three velocity components and two turbulence profiles corresponding to the synthetic_turbulence_input_type defined in turbulence_model_parameters.
