Defines and initializes globally-accessible data.
USER_GLOBAL_DATA ("name") {parameters...}
Qualifier
User-given name.
- value
(real) [=0]
- The value of the user global data.
This command defines and initializes a variable that is accessible and changeable from a number
of places. For
example,
USER_GLOBAL_DATA( "var_1" ) {
value = 10
defines a variable called
"var_1" and initializes it to the value 10. This
variable may then be accessed or changed by a user-defined function, and the changed
value accessed by another user-defined function. It may be used by a multiplier
function in two ways: either as the return value of the multiplier function itself,
or as the value of the curve fit variable for one of the curve fit types. See the
MULTIPLIER_FUNCTION command for details. The variable may
also be changed on the command line during a run through the acuSig utility, for
example,
acuSig -data "var_1 = 332"
