udfGetActSpecId()
The identification number of the current species being solved.
specId = udfGetActSpecId( udfHd ) ;
AcuSolve User-Defined Function Global
- udfHd
- The opaque handle (pointer) which was passed to the user function.
Return Value
- specId (integer)
- Identification number of the species being solved. If not within a species stagger, the return value is zero. The return value is one based.
Integer specId ;
specId = udfGetActSpecId( udfHd ) ;Errors
This routine expects a valid udfHd.
