Energy equation in nanoFluidX is implemented so that it accommodates
for conduction and convection heat transfer with initial or Dirichlet boundary
conditions.
The rate of temperature change of a specific material is given by:
(1)
dTdt=1cpρ∇(κ∇T)
With
t
being time,
T
being the temperature,
k
the coefficient of thermal conductivity,
ρ
the density and
cp
the specific heat capacity of the
material. In SPH form the above analytic expression becomes
(2)
(dTdt)i=1cp,i∑j4mjρiρjκiκjκi+κjTij∇Wij∣∣rij∣∣⋅n
Where, the indices
i
and
j
standing for so-called owner and neighboring
particles respectively, and the
ij
index is a difference between the respective
variables of particle
i
and particle
j
. The
m
stands for mass of the particle, the
∇W
is the gradient of the kernel,
r
is the position vector and
n
is the unit coordinate vector.
If you want to use the energy transport option, you need to turn the feature on by
setting the energy_transport flag in Simulation parameters to
true. Once this step is completed, you can opt for desired output, which can be
either temperature or rate of temperature change (flux). The code will not work if
an output is required and the energy transport flag is turned off.
Finally, set up the phase parameters, which are initial temperature
temp_0) in [K], evolve temperature flag
evolve_temp), specific heat capacity of the material
heat_cap) in [J/kg/K] and heat conduction coefficient of the
material (
heat_cond) in [W/m/K].
Note: Regarding the
evolve_temp flag, this parameter is valid only for
WALL or MOVINGWALL phases. If the
evolve_temp flag is set to false, or if it is not defined
(default is false), the set initial temperature will remain constant throughout
the simulation. If set to true, the initial temperature will evolve in time and
the temperature of the WALL or MOVINGWALL will
be influenced by any surrounding phase. For FLUID phases, the
temperature always evolves.
