Body Force (Acceleration)
The body force, defined through acceleration in units of [m/s2], can be varied over time using an input file.
| time | Bodyforce_x | Bodyforce_y | Bodyforce_z |
| 0 | 0 | 0 | -9.81 |
| 1 | 0 | 0 | -5.6 |
| 3 | 2.1 | 4.3 | -7.2 |
There are no headers of any sort in the file.
The difference between input time values does not need be constant. The value of the gravity is interpolated linearly at each time step of the simulation between the closest greater and lesser time values of the input file.
| bodyforcefile | inputFileName.txt |
The data of this file are read one time at the beginning of the simulation. The start time in the prescribed motion file cannot be smaller than the initial time of the simulation.
No damping function is used.
