HM-3570: Alter Cross-Sections With Domains
In this tutorial, you will use domains and handles to increase the gauge thickness.
![](../../../images/hypermesh_spring_wire.png)
Open the Model File
In this step, you will open the model file, spring.hm.
Change Gauge Thickness
In this step you will change the gauge thickness.
