HM-3670: Position a Dummy Using Limiting Constraints
In this tutorial, you will learn how to position the H-point of the dummy on a seat cushion.
This helps to reduce design and remeshing of the seat based on the pre-stress analysis. To do this exercise you will be using a limiting constraint and freehand morphing.
![](../../../images/hypermesh_seat_cushion.png)
Open the Model File
In this step, you will open the model file, dummy.hm.
- Open the model file, dummy.hm.
- Review the model.
Create Constraints
In this step, you will create constraints.
Morph the Part
In this step, you will morph the part.
