Browsers supply a great deal of view-related functionality by listing the parts of a model in a tabular and/or tree-based
format, and providing controls inside the table that allow you to alter the display of model parts.
FE geometry is topology on top of mesh, meaning CAD and mesh exist as a single entity. The purpose of FE geometry
is to add vertices, edges, surfaces, and solids on FE models which have no CAD geometry.
Use the Model Checker to configure solver validity checks, modify and create new checks and corrections,
and fix modeling issues in an automatic or manual way.
Tools and workflows that are dedicated to rapidly creating new parts for specific use cases, or amending existing
parts. The current capabilities are focused on stiffening parts.
Run Model Quality Checks on Selected Entities
Use the Model tool to quickly run solver-related checks on all/selected entities in the model and apply auto-correction where defined.
Manage and Run Checks Use the Model Checker to configure solver validity checks, modify and create new checks and corrections, and fix modeling issues in an automatic or manual way.
