If desired, define the solver differential equation using the User-Defined tab, which
will allow you to specify the properties of the equation using user subroutines.
From the Properties tab, click the User-defined
properties check box.
Click the newly added User-Defined tab.
Define the user subroutine.
Provide an expression with the USER solver function with parameters
being passed to the user subroutine.
Alternatively, activate the Use local file and function
name check box to specify a local file where the
subroutine code can be accessed by the solver.
If this option is not specified, MotionSolve will search for a subroutine following its user subroutine
loading rules.
Select a function type from the drop-down menu.
Select the local file for the subroutine.
The type of file to be specified will depend on the selected function
type. For example, if DLL/SO is selected, you can
specify a file with a .dll extension (for Windows)
or an .so extension (for Linux).
Specify the function name in the subroutine that defines the entity, or
accept the default name provided by HyperWorks.
