Set parent modules with CMS SE representation in H3D format to be used for analysis in lieu of child module representations
when rolled up, or use the child representations when rolled down.
To manage any of the modules shown in the Assembly Browser, right-click on a module and select Edit Representations. This opens the Edit Module tab, and the Representation sub-tab is shown.
Create assembly hierarchy and assign ID ranges to the modules from external
.csv files.
It is also possible to assign ID ranges manually. It shows the detailed summary of module
ID ranges in terms of assignment, validity and conflicts. Right-click on a module in the
Assembly Browser and select Batch Create Module
to open the dialog.
Assembly Hierarchy Creation and ID Assignment from an External CSV File
Click Import to open the Import modules and id
ranges dialog. Load a .csv file that has assembly
hierarchy and ID assignment definition. Select the modules and click OK to create modules in hierarchy and assign ID
ranges.
All of the modules and corresponding ID ranges are populated on the left hand side. Use the
Assign arrow to create the modules and assign ID ranges. You can also unassign the ID range
by clicking the Unassign arrow.
Assignment, Validity and Conflicts Status of Module ID Ranges
The detailed summary of module ID ranges in terms of assignment, validity and conflicts is
shown in the ID Manager with color coding. ID ranges for the modules can be exported in
external .csv files using the Export button. The assigned ID ranges for
modules can be modified/changed using the Edit icon. It is possible to visualize all modules
in an assembly or only child modules with representation files. There are also options to
view Open and Open+ ranges.
