Frequency Set Manager
Create standard analysis frequency sets that will be automatically used in setting up analysis frequencies in NVH analysis.
- From the Analyse ribbon, click the Frequency tool.
Figure 2. Frequency Set dialog - From the Frequency Set dialog, define the following options.
- Name
- Enter a frequency set name.
- Incr type
- Select Linear or Log as the frequency increment type.
- Min/Max/Incr size
- Enter the appropriate values in these fields.
- Click Create to save the changes made to the frequency sets or click Cancel to discard the changes made since the last update, and exit the dialog.
- Review the frequency sets in the Frequency Sets Browser.
Figure 3. - To delete a frequency, select the row corresponding to it, right-click, and select Delete from the context menu.
- To edit a frequency set, select the row corresponding to it and click the fields that need to be edited.
