Response Point Manager
Create defined response points that will be automatically used in setting up output requests in NVH analysis.
![](../../../images/icons/icon_response.png)
![](../../../images/response_point_mgr_guidebar.png)
- Select the tagpoints/nodes by graphically picking them from the model or from the Advanced Selection menu options while specifying the response type.
- For structural response points, a dynamic LCS can be added by clicking the entry in LCS column. This opens the LCS manager and you can create a LCS in which the response is calculated.
- Review the response points in the Tags Browser.
Figure 3. - To delete a response point, select the row corresponding to it, right-click, and select Delete from the context menu.
