OptiStruct is a proven, modern structural solver with comprehensive, accurate and scalable solutions for linear and nonlinear
analyses across statics and dynamics, vibrations, acoustics, fatigue, heat transfer, and multiphysics disciplines.
Elements are a fundamental part of any finite element analysis, since they completely represent (to an acceptable
approximation), the geometry and variation in displacement based on the deformation of the structure.
The different material types provided by OptiStruct are: isotropic, orthotropic, and anisotropic materials. The material property definition cards are used to
define the properties for each of the materials used in a structural model.
High Performance Computing leverages computing power, in standalone or cluster form, with highly efficient software,
message passing interfaces, memory handling capabilities to allow solutions to improve scalability and minimize run
times.
Contact is an integral aspect of the analysis and optimization techniques that is utilized to understand, model, predict,
and optimize the behavior of physical structures and processes.
Coupled Frequency Response Analysis of fluid-structure models, commonly termed Acoustic Analysis, is generally performed
to model sound propagation within a structural cavity, such as the interior of a vehicle or a musical instrument.
Acoustic modeling in finite and semi-infinite domains is essential in the prediction of quantities such as external and
radiated noise in vibro-acoustic problems. Infinite elements are a popular way of modeling these domains.
Exterior acoustics is the modeling of sound propagation in the unbounded domain. Adaptive Perfectly Matched Layer
(APML) is an important method to modeling these domains. APML is supported for Direct and Modal Frequency Response
Analysis.
Radiated Sound Output can be requested for grid points on the structural surface and in the exterior acoustic field.
Grid points are used to represent microphones to record the radiated sound, sound power, and sound intensity.
OptiStruct and AcuSolve are fully-integrated to perform a Direct Coupled Fluid-Structure Interaction (DC-FSI) Analysis based on a
partitioned staggered approach.
Aeroelastic analysis is the study of the deflection of flexible aircraft structures under aerodynamic loads, wherein
the deformation of aircraft structures in turn affect the airflow.
OptiStruct provides industry-leading capabilities and solutions for Powertrain applications. This section aims to highlight OptiStruct features for various applications in the Powertrain industry. Each section consists of a short introduction, followed
by the typical Objectives in the field for the corresponding analysis type.
This section provides an overview of the capabilities of OptiStruct for the electronics industry. Example problems pertaining to the electronics industry are covered and common solution
sequences (analysis techniques) are demonstrated.
OptiStruct generates output depending on various default settings and options. Additionally,
the output variables are available in a variety of output
formats, ranging from ASCII (for example, PCH) to binary files (for example,
H3D).
A semi-automated design interpretation software, facilitating the recovery of a modified geometry resulting from a
structural optimization, for further use in the design process and FEA reanalysis.
The OptiStruct Example Guide is a collection of solved examples for various solution sequences and optimization types and provides
you with examples of the real-world applications and capabilities of OptiStruct.
The Acoustic Analysis section provides an overview of the
following analyses.
Coupled Frequency Response Analysis of Fluid-Structure Models
Coupled Frequency Response Analysis of fluid-structure models, commonly termed Acoustic Analysis, is generally performed to model sound propagation within a structural cavity, such as the interior of a vehicle or a musical instrument.
Acoustic Infinite Elements
Acoustic modeling in finite and semi-infinite domains is essential in the prediction of quantities such as external and radiated noise in vibro-acoustic problems. Infinite elements are a popular way of modeling these domains.
Adaptive Perfectly Matched Layer Method for Exterior Acoustics
Exterior acoustics is the modeling of sound propagation in the unbounded domain. Adaptive Perfectly Matched Layer (APML) is an important method to modeling these domains. APML is supported for Direct and Modal Frequency Response Analysis.
Radiated Sound Output Analysis
Radiated Sound Output can be requested for grid points on the structural surface and in the exterior acoustic field. Grid points are used to represent microphones to record the radiated sound, sound power, and sound intensity.
