Aeroelastic Analysis
Aeroelastic analysis is the study of the deflection of flexible aircraft structures under aerodynamic loads, wherein the deformation of aircraft structures in turn affect the airflow.
![](../../../images/solvers/aeroelastic_overview.png)
Figure 1. Aeroelasticity Overview
The interaction between Elastic forces and Aerodynamic forces can be analyzed, as part of the Static Aeroelasticity solution.
