Composite Modeling
Composite modeling techniques used in Radioss.
Each Layer with at Least One Solid
Mixed Approach (Middle Layer Thick)
Sandwich Shell Approach
- The first is composite shell with isotropic layers (orthotropic in z direction). For example, by Windshield modeling. Where, material LAW27(PLAS_BRIT) or LAW36 (PLAS_TAB) can be used.
- The second is composite shell with orthotropic layers (orthotropic in x, y and z). For example, Sandwich shell with external fiber glass layers and internal foam layer. Where, material LAW25 (COMPSH) and all shell formulation can be used, except for QEPH.
