/FAIL/ENERGY
Block Format Keyword Describes an energy density failure model.
/FAIL/ENERGY/mat_ID/unit_ID
E1 E2 fct_ID Xscale I_Dam
Optional Line
fail_ID
mat_ID Material identifier.
(Integer, maximum 10 digits)
unit_ID Unit Identifier.
E1 Maximum energy density. 2
Default = 130 (Real)
[ J m 3 ]
E2 Failure energy density. 2
Default = 230 (Real)
[ J m 3 ]
I_Dam Damage calculation flag. 4
=1
Only forces are reduced. The stress tensor is not damaged.
=2
Stress tensor is reduced (used before version 2018).
Default = 1 (Integer)
fct_ID Function identifier for f ( ε ˙ ) . It is the function of energy density E1 and E2 scaling factor versus strain rate.
(Integer)
Xscale Scale factor for abscissa of the function.
Default = 1.0 (Real)
[ 1 s ]
fail_ID Failure criteria identifier. 3
Example (Metal)
In this example, fail_ID is used to scale the energy density (E1 and E2) for different test strain rates.
#RADIOSS STARTER
/UNIT/1
unit for mat
#              MUNIT               LUNIT               TUNIT
                  Mg                  mm                   s
/MAT/PLAS_TAB/1/1
Metal
#              RHO_I
         2.788714E-9                   0
#                  E                  Nu           Eps_p_max               Eps_t               Eps_m
               68000                  .3                   0                   0                   0
#  N_funct  F_smooth              C_hard               F_cut               Eps_f
         1         0                   0                   0                   0
#  fct_IDp              Fscale   Fct_IDE                EInf                  CE
         0                   1         0                   0                   0
# func_ID1  func_ID2  func_ID3  func_ID4  func_ID5
         2
#           Fscale_1            Fscale_2            Fscale_3            Fscale_4            Fscale_5
                   0
#          Eps_dot_1           Eps_dot_2           Eps_dot_3           Eps_dot_4           Eps_dot_5
                   0
/FAIL/ENERGY/1/1
#                 E1                  E2  funct_ID              Xscale     I_Dam
                 0.3                0.34        18                             1
/FUNCT/18
scale factor for energy density E1 and E2
#        strain rate        scale factor
#                  X                   Y
                   0                   1
                  50                 0.5
               10000                 0.5
/FUNCT/2
True Stress-True plastic strain
#                  X                   Y
                   0                 124
                 .01                 150
                 .02                 165
                 .04                 184
                 .06                 196
                 .08                 203
                  .1                 206
                 .12                 210
                 .14                 213
                 .16                 217
                 .18                 220
                  .5                 240
                1000                 240
#enddata
  1. The element is deleted, if D=1 for one integration point.(1)
    D = E − E 1 E 2 − E 1
  2. The energy density is the current internal energy of the element divided by the current element volume. The value will be different than the element time history /TH/element Internal energy (IE) which is the current internal energy divided by the "initial" element volume.
    clip0007
    Figure 1. Energy Density Model Failure
  3. The fail_ID is used with /STATE/BRICK/FAIL and /INIBRI/FAIL. There is no default value. If the line is blank, no value will be output for failure model variables in the /INIBRI/FAIL (written in .sta file with /STATE/BRICK/FAIL option).
  4. The I_Dam option improves damage calculation and stability calculating damage, it is not available for shell elements and material laws N° < 29 . It is available for the /MAT/LAW25 (CRASURV) law, if using /PROP/TYPE51 or /PLY and /STACK options.
