/IMPL/LBFGS/L
Engine Keyword Change the maximum number of BFGS quasi-Newton method for implicit nonlinear.
/IMPL/LBFGS/L
L
| L | Maximum number of BFGS vectors. |
- /IMPL/NONLIN/2 should be defined.
- If L
=0 or /IMPL/LBFGS/L is not defined,
L = L_A is defined in /IMPL/NONLIN/N.
When this keyword is defined, the new update vectors are accumulated over the old ones by sliding down the set of vectors loosing the oldest ones.
